Adjustabel cam sprocket innova
- Lung Mike
- Fahrzeuge: Honda Dax
Honda C125 - Wohnort: NRW
Re: Adjustabel cam sprocket innova
I have One for you,Maybe.
I am in Duisburg.
I am in Duisburg.
- Lung Mike
Thats it,what i have........write u PM
Unfortunately, thats not the same.. Innova sprocket got 2 bolts whit 34 teeth..
Ask Karl Retter!
the Pickup of the Ignition is modified too?
No, it depends from each other...
Takegawa sounds good.
Whats the maximum Speed of this Innova you ever reached ?
Maximum now is 125.95km/h on GPS thats about a 140km/h + on a innova dachboard/counter..
Not Bad...
means she runs about 100km/h in Daily use...
A Daytona Head is mounted and thats all, right Brother ?
No, that would be to easy.. Faito 148cc, cardinals racing big valve head. Head ported, kitaco valve springs, daytona cdi, mikuni vm26, takegawa exhaust and faito stage 2 cam. It wil do a litle bit more whit the timing chain on time, and whit a yoshimura yd28 i think..
And yes you can easy crouse @100km/h
Actually 125km/h is nothing.. I see innovas running on youtube @ 185km/h like its nothing
We got what we have to know...
Mikuni VM26
a Carb Innova, not a Injection...
What Gas Flow can be powered out of a 26mm Carb IGN ?
Long gone IGN, anyway... not the World on a 4-Stroker...
Does the Clutch make Problems Innovacub ?
Mikuni VM26
What you mean with "what gas flow can be powerd out of a 26?IGN hat geschrieben: ↑Di 6. Nov 2018, 16:01We got what we have to know...
Mikuni VM26
Clutch is a stronger one, a litle bit stiffer with switching the gears but it works great. It dont slip..
Aaaahhhhh, the more Fuel you can burn per Second,
results in more Horsepower simply said...
The less you need off Fuel, the better you drive of course is Off-Topic.
A "simple" Carburetor of 26mm Diameter that mixes air and fuel will Limit that
available Horses more than Injection...
You got your adjustabel cam sprocket, your "simple" Mikuni and a Ignition
that does not know what these other two things do actually...
Zuletzt geändert von IGN am Di 6. Nov 2018, 21:14, insgesamt 2-mal geändert.
We gonna put the same kit on my brother's innova, bit with the takegawa ficon2 controller, so i let you now wich is the fastestIGN hat geschrieben: ↑Di 6. Nov 2018, 21:06Aaaahhhhh, the more Fuel you can burn per Second,
